Feature Request: Multiline Comments
I want to put a multi-line comment into 'Comments' -- A copyright notice, my email, phone number and web site.
I've tried typing it, but pressing Enter, Shift+Enter or Ctrl+Enter all do nothing.
I tried writing my comment in Notepad and pasting it in, but it only accepts the first line.
If I right-click the file in Windows and select 'Proerties,' I can go to the details tab and enter multi-line comments there.
Can you make the Comments field a multi-line text box?
Thanks for MP3Tag! It's been invaluable to me as a distribute my music!
  • Barry
See the documentation on how to customize the tag panel.
It describes among other things to set the comment field to be a multiline input box
Shift+Enter adds the contents of the field as default value.
See also the documentation about keyboard shortcuts
Thanks for that, this is exactly what I needed!
