Feature Request: Partial Re-Read / Refresh on Directory w/Right Click
Sometimes I'm copying files into my directory structure while waiting for mp3tag to finish reading files. With 10K music files, the process takes a minute or more. It would be handy to have mp3tag do a partial refresh / reread of a directory rather than the entire directory tree.
Suggestion: Provide an option to refresh a single directory with a right-click on an existing file's Path. Example: if I add another *.mp3 file to C:\Music\Rock\Favorites, then right-clicking on any existing Path in that directory could provide:
-> Refresh Favorites
-> Refresh Rock
-> Refresh Music
Selecting 'Favorites' would cause mp3tag to re-read / refresh just that one directory, and then the new file would show up and could be edited, etc.
If you use the function to add a folder then you could naturally add a folder that you have already loaded - this would refresh the list and show also the added files.
My first thought for a workaround was to just run a second instance, but that appears to be a highly contested topic. Your request is the most important part of what I would need to not want multiple instances. In my comment here Running Multiple Instances of MP3Tag - #17 by mark5000432 I proposed something similar, that I hope would be useful to more than just me.
