Feature Request: Play Track Hotkeys
Currently I have to right click and select open as I'm editing.
Ctrl + Shift + T or F4 is track play in Windows.
Requesting this to be added to the Mac version.
You can play from within the app using the Space keyboard shortcut, which triggers macOS Quick Look.
I'll give that a try, that would be perfect
This works really well, I wish the WIndows version worked like this as well.
