Allow us to add and remove Icons on the toolbar.
Allow us to make the toolbar icons larger.
Allow us to specify a default directory to save the newly tagged files. (different from the favorite directory we can specify in Options Directories)
An example of the add/remove icons.. I only use one icon, "Filename -> Tag" I usually click the one next to it each time as its a very small icon. If they were larger and if I could remove all the others that look similar that would be sweet.
Thanks, Bill
PS. i donated after trying your program for a few months (a few years back)
Thanks for all your work!!
