Excuse an "old" man, who is completely new to the mp3-format.
As i was going to undertake a major conversion to mp3-format, i found it very surprising that none of the applications i tried out there seem to support the irsc-code. Even worse, there does not seem to be a tag for it, eventhough the information is stored on the cds, so it could be extracted and tagged.
Some people suggested using the comment.tag, if you have the irsc-code allready.
http://www.ifpi.org/isrc/isrc_handbook.html#Heading296
Q: How would i do to get the irsc-info i so much need in to a tag with the mp3tag application. I would consider a small donation if this could be solved.
Can this universal tag editor do "the job"
Thanks.
