Addtionally, are there any plans to enable scripting functions in the Filter?
It would be very helpful to be able to maintain a history of past filters in the Filter text box, I currently keep a text file that contains the different regular expressions I use to filter.
I like the history idea especially since most of the other areas of Mp3tag have a history.
What exactly would you like to achieve with the scripting functions?
Functionally: If(path contains 'various' or 'compilation' AND AlbumArtist is blank)
The actual entry would use the scripting functions as they are.
Does that help?
Ah, OK, that makes sense.
