Hello, and thanks a lot at first for the great work.
I would an option to be available : Don’t play track at clic.
It’s about modification of tags, numbers and names of tracks. At quick clic, the soft open the track in the default player. It could be annoying when renaming the tracks…
Thanks for attention.
See the Ctrl-O Options>Tools>Default tool Use special program at double clicks
If you set that name for the program to -no action-, then no program will be started when you double-click.
What exactly do you mean with "quick clic"?
A double-click with the left mouse button?
Or do you mean the first entry "Play" in the right mouse-click context menu?
'Play' is using the player app that is set as the default app in your Windows settings for this type of music files.
Many thanks Ohrenkino.
I was talking about double clicks.
