Since the custom Tool commands (Options>Tools) are frequently used by some users, is there a reason why the Tools menu is reserved for only the default items?
Being able to more quickly access custom commands from the main menu, similar to Actions, would be handy and also provide a consistent main menu location for the user-created commands.
While the context sub-menu location does work I've always found the main menu more convenient and easier to access. I couldn't imagine having Actions located in the context menu, for example, yet Tools aren't that dissimilar.
