Features suggestion: Importing tags from text files within an Action Group
I very often use the ‘Import Tags from Text Files’ converter function and then run an Action Group afterwards. This is partly related to this thread. At the moment, this requires two steps.
It would be nice if the import mentioned above could be triggered via an Action Group. Although there is a "Import text file" action, this merely imports the entire contents of a text file into a single, specified tag.
If this is technically feasible, perhaps it is something worth considering it for a future version of MP3Tag.
In any case, thank you for considering.
Best regards
Christian
Do you ask about a new Action type like Convert -> Text file to Tag?
A new Action that should be called "Import Tags from Text Files"?
Hi @LyricsLover ,
Yes, that’s what I meant.
Yes, I think that would be a good name for it because it clearly distinguishes it from the current ‘Import Text File’ action.
Best regards
Christian
I agree it could be handy to re-use the functionality from the Convert functions as additional Action types. Anything to potentially reduce manual steps in a workflow seems worthwhile.
In many cases this could be a valid approach.
And now comes the "but":
But which workflow need esp. such an action to import data from an external text file where (if I read the linked thread correctly) the export is just one step of many.
I would like to draw your attention to copying the whole tag from several source files and pasting them in toto to the target files.
Or: instead of the use of an external text file, use Edit > Copy as text and then Convert >Text file -Tag with source "text" from the clipboard.
Admittedly a tough one. I've used Import text file to grab data from tag source .settings to then automate updating and exporting a tag source .src via sets of Actions (sorry for the shameless plug):
It might've been cool to be able to grab multiple values from the settings into TEMP_ tags in one step. Multiple steps of complicated regexes are used to find each value; detecting each tag using the format string option is more akin to the strict format of Guess values. That alone attempting several chained $regexp() in an already strict method of detection, maybe the feasibility isn't likely for me and just need to stick with multiple steps.
Now that you point it out, most of the Converters can be easily replicated using combinations of Format value and Guess values. I suppose Auto-numbering wizard was the one I got excited about the most as that's got the most potential as an Action type.
It was more to encourage users moving onto creating their own Actions if they saw a Converter readily available but the system's powerful enough as it stands.
Hi @ohrenkino
I am familiar with this function and I use it as well.
However, in certain circumstances, I do not want to copy all tags one-to-one from one set of audio files to another, and by importing from a .csv file with a consistent structure, I am able control very precisely which tags I want to import and which I don’t.
I know this function exists. However, I can’t see any advantage compared to importing from a text file.
Using converters in Action Groups would simply be a nice-to-have feature.
Best regards
Christian
To me the advantage is:
I can edit the export format string on the fly and to do not have to open a script, edit it, save it and then call it.
The data ends up in the clipboard and can be accessed there immediately, e.g. with Convert>Text (file) - Tag and also a matching format string with a preview, defined on the fly.
It saves me the bother do define a standard filename for the (csv-) data.
The data does not have to be CSV but can be any format with unique separators between the fields.
But if this is considered beneficial is, of course, up to ones accustomed workflow.
Just another idea:
What about if the action gets some intelligence:
a single field as target field lets the action behave as currently implemented: the whole text file gets imported into the named field.
if more than 1 field is set as target fields, the action behaves like the converter and imports a single line as record into 1 file but several fields.
Hi @ohrenkino ,
That could be one way of implementing this.
Anything that can be automated reduces the likelihood of errors. That’s why I’m a big fan of the Action Groups and scripting functions in MP3Tag.
Best regards
Chrisitian
I fully support this feature request. Being able to use Text File → Tag within an Action Group would make it possible to automate the assignment of one text-file line per selected audio file, regardless of the number of tracks.
This would be especially valuable for integrating externally generated metadata into automated tagging workflows, without requiring manual interaction with the converter.
Alternatively, it would also be useful to know how the converter works, but I don’t think @Florian is willing to make that public. Otherwise, he would have done so already. :grinning_face:
Best regard
