Hy,
I have add the field "MIXARTIST" with this parameters
but this field is always empty, why ?
Rgds
Akhlan
Hy,
Rgds
Akhlan
Sorry, I cannot see what you want - please check the post.
Hi Akhlan,
You can check whether this file has the MIXARTIST field at all via the extended tag dialog at [Alt+T].
Kind regards
Florian
Can you post a screenshot of the extended tag dialog?
Kind regards
Florian
What's "extended tag dialog" ?
Well, you might wander through the various menus and find a function like "Extended tags...".
Give it a try.
Alternatively, press Alt-T to open it.
Check the list of tag fields you find in a file without MXIARTIST and see if you find an entry for that field.
If there is not entry for MIXARTIST then MP3tag cannot display anything.
What happens if you enter data in the column MIXARTIST? Does it stay there?
Generally, you have to input some data in a field as empty fields are not allowed.
It could be that you do not have the right mapping for Vorbis comments.
See e.g. this page for the mapping:
http://wiki.hydrogenaud.io/index.php?title=Tag_Mapping
There is a Mix-DJ (maps to DJMIXER) and a Mix Engineer (maps to Mixer)
So, see File>Options>Tags>Mapping
and create a new entry e.g.
Source:Mixer
Target: MIXARTIST
and see if it does what it should
Perfect, tks for all
