Hi. Does anyone know of a way that I can get songs to be renamed, starting with the cut number of each, but with a leading "0" just for those cuts with one digit? So, for example, a cut that started with "1 - " would be changed to "01 - ", but cuts with two digits would remain unchanged (e.g., "12 - " would not be changed.
Thoughts/advice much appreciated!
Thanks,
DB
