Filename and tag
Hello, I have one doubts with the options to pass the name of the file to the Tag. The name of the file is 01. song.mp3
The program by defect gives the name 01.song to the Tag, and I want to know if there is some way so that it calls 1.song (without the 0).
If you want to have the filename in the tag, there are several fields in the tag you can edit (artist, title ect.).
To import filename without leading 0 to e.g. title you can use the Filename-Tag-Converter with Formatstring 0%title%, read help & FAQ for explanation how to use converters.
Regards
nickless
