Filename length restrictions
Does MP3Tag have any restrictions on filename and/or path length? I just noticed tonight, while attempting to modify some tags in FLAC and MP3 files that I had already custom-tagged last week, that MP3Tag reported that it was unable to access certain files for writing, although those files were successfully loaded into MP3Tag and existing tags read and displayed. The files it had problems writing to all have long filenames, and all of those filenames had been generated by me via MP3Tag from track numbers and titles. The longest filename of the problem files was 68 characters, including ".flac", and the full path with filename was 273 characters. I made a copy of the file with only 43 characters in the filename (248 characters path + name), and MP3Tag had no trouble writing modified tags to it.
I also noticed that my file manager of choice (Directory Opus v11.19) would not display track length or descriptions in its lister window for all the long-filename files, but still correctly displayed the contents of the COMMENT tags for them. It looks like the longest path + name I can have in order for Directory Opus to report track length and descriptions is 259 characters.
I don't remember ever coming across this problem before with either MP3Tag or Directory Opus, so I wonder if this is something that has maybe been caused by a recent change to my system?
By the way, all of these files play without problems in various media players (foobar2000, PotPlayer), and have their media details correctly reported by MediaInfo.
Yes, just like many other programs have: the total length is limited to 254 characters.
The filename is a fully qualified filename then with drive letter and full path.
This restriction is kept to be as compatible as possible.
For example read there ...
NTFS path/file length exceeded
/t/10690/1
/t/16455/1
DD.20161231.1043.CET
Yes,, the problem is not only evident with Mp3tag and filemanagers but also with the burning software
And that is why I my folder for editing music is named "M", and for storing "Mus"
And If I had enough drives, I would take it even further and store content of "Mus" in the main folder on the drive used only for music, renaming then also "M" to "+" [so that it would be displayed at the top, so that I could navigate to it quickly]
