Filename-Tag Format
Please can you help how I can convert the following Filename to Tag to the following Format:
The Filename is: Summer Madness - Kool & The Gang (Jam Master's Disco Mix)_pn
When I sue the >> Convert >> Filename - Tag
Format String: %title% - %artist%
The result is:
Title: Summer Madness
Artist: Kool & The Gang (Jam Master's Disco Mix)_pn
This is partial correct but the issues is " (Jam Master's Disco Mix)_pn" is part of the title, How do I get this to be part of the title?
Therefore the result I am looking for is:
Title: Summer Madness (Jam Master's Disco Mix)_pn
Thankyou in advance for your support
You can do that in 2 steps:
First use this Format String to import 3 parts in your tags:
%TITLE% - %ARTIST% (%COMMENT%
This will surpress the opening bracket. Therefore you need a second step:
Converter Tag -> Tag
Field: TITLE
Format string:
(%TITLE% %COMMENT%
You could delete the content of COMMENT afterwards.
