I am using version 2.35 and have loaded a bunch of files (~765) and have set up a custom format string, but the ok button is not active. When I go to filename -> tag everything else works (preview, cancel, help), but no the "ok". Here is my string:
Correctomundo. Sometimes it is the simplest things. I set up that way in tools/options, but when I went to filename ->tag it removed my . Wierd, works now. Thanks.
One more fix needed. For albums that don't have a comment, it doesn't add tags for album and yar. Is there a method to do an if statement? For example, if (%comment%), . . ., ....) I put stuff like remaster, disc 1, etc. as a comment, but not all disks have comments. Suggestions?
Thanks for all of the help guys. One more issue. Since sometimes I had two items in parenthesis {(remaster) (disc 1)} I had to change my string a bit. I made the comments (remaster, mfsl, etc.) now {}. Anyhow, with this string:
everything works great except i get unformatted plus the artist name in the artist section (unformatted Punk Floyd). Where is my error? Every other tag worked great.
