hi! I'm trying to figure out a way to copy the filenames of music to the Title column, but removing any numbers before the actual name. So for example
05-Really Cool Track becomes Really Cool Track
It would be great either by number of characters to remove or however many up to and including the dash.
Thanks very much!
The good thing is, that there is a special character between the number and the title. You can use the converter "Filename - Tag" with a format string
%dummy%-%title%
The %dummy% placeholder is a special field, which simply drops the content it matches. You can learn more on the converter and format strings at
