i have filename as this-
Abc_Kpr_01_Bcdijklm-donload-sharehouse.mp3
i want to get the filename as this-(the fourth word in the string)
Bcdijklm
how can i accomplish this? thanks
Bcdijklm
As "the fourth word" is something that can only be determined by the delimiters, the converter works only with a certain pattern.
If the filenames are structured like the one you gave as example, use this mask in the converter filename-filename
%1_%2_%3_%4-%5
use as target pattern
%4
