I want to create an action that uses the text in the TITLE field to populate the fields iTunes uses for classical music.
iTunes uses these fields:
CONTENTGROUPING (name of work)
MOVEMENTNAME (name of movement)
MOVEMENT (movement number)
MOVEMENTTOTAL (total number of movements in work)
The title field in my classical music is typically laid out like this:
CONTENTGROUPING - MOVEMENT. MOVEMENTNAME
For example:
Concerto in D minor for two violins, BWV 1043 - 1. Vivace
Can anyone help create an action from this to populate those fields?
Thanks!
