I have over 11,000 mp3's and noticed a couple of filenames that did not conform to my standard which is
Artist - AlbumTitle - TrackNo - TrackTitle
Is it possible to create a filter that will show me the filenames that do not conform to this structure?
Thankyou
You can't check the field contents in the filter, but filtering by
and inverting the result will show you all files that don't match your naming scheme.
Florian
Thanks for this, but it does not seem to work. I am using the _FILENAME field to filter on.
For instance if I have a filename that says
Artist - AlbumTitle - TrackNo -TrackName (note the missing space just before the track title), this filter does not exclude it and then include it on an Invert. It just carries on including it in the first place.
Regards
Use .* - .* - .* - .*to specify your standard, then [X] invert to show the non-compliants.
