Filter for finding track number differences
I am looking to find a filter to highlight any difference between the track number and the track number in the Filename if possible please?.
I have notice a few tracks where there is a difference and just wanted to check my whole DB to highlight those that are a problem.
just as an example:
         Filename                  Track #           Title
11 Led Zeppelin - Good Times Bad Times.flac 01/09 Good Times Bad Times
Thanks
This should work, including both for single and 2-digit track numbers in both the filename and title.
"$if($eql($num($left(%_filename%,2),2),$num($left(%track%,2),2)),yes,no)" IS no
Just as a speciality in this case as both strings start with a number:
"$ifgreater($strstr($num(%_filename%,2),$num(%track%,2)),0,Yes,no)" IS no
Many thanks to you both for helping me.
That worked well.
It identified 221 tracks out of more than 130000 that needed to be corrected.
Thanks again :slight_smile:
