Hi, a question.
I use filters with operators like HAS/IS/GREATER/LESS/EQUAL/MATCHES. However, if I want to use a “start with” or “end with” filter, how should I set the filter? An example: Filter All records where the title field ends with "Dj Reto" .
Your effort is much appreciated.
Try "End with"
%title% MATCHES "Dj Reto$"
Start with:
%title% MATCHES "^Dj Reto"
Thanks!!
I didn't know how to place the start “^” and end “$” inside a filter ..
You can find the explanation for "line anchors" in a regular expression in the documentation:
Line anchors
^ matches the start of a line
$ matches the end of a line
Thaks so much…
I read the documentation, I couldn't apply the rule
