Hi (again)
I want to filter titles that have: 12" Mix
(Only in this order) for example I don't want 12" Remix
I tried
title HAS "12" Mix"
But it doesn't produce the correct results
What am I doing wrong?
Thanks
Hi (again)
I tried
title HAS "12" Mix"
Thanks
is this better:
%title% HAS 12 AND %title% HAS " Mix"
Thank You
It's better but it still produces:
12" Vocal Mix
Which I don't want
what about
%title% HAS "12"" Mix"
That's worse
Also it's producing results without Mix in the title which is strange and is similar to my original attempt
Here is a new one:
%title% MATCHES "12. Mix"
Yes that's better!
Almost there
Although I'm still getting: Original 12" Mix etc
I should have been more clear from the beginning
I'm looking to filter (12" Mix) not 12" Mix
Sorry for the confusion!
Thank You
what about this one:
%title% MATCHES "\(12. Mix\)"
That's It!
Thank you very much.
I appreciate it
Excerpt from the MP3Tag-Helpfile:
It is not possible to filter by strings containing double quotations marks. This is a limitation of the feature.
And to counter that limitation I have made a rule among all of my file, that instead of quotation mark
I always use two apostrophes
A plain and simple workaround. Depending on you local settings [of the font] they might look exactly the same
