Filter upgrades
#1
Hello
I would like to propose two things:
1] A feature of reversing the filter search, by clicking on an icon
If one uses a short expression like
title HAS "ABC"
it's easy to reverse the search by writing
NOT title HAS "ABC"
But when you have something like
$ifgreater($strstr($lower($left(%TITLE%,6)),$lower($left(%ALBUM%,6))),0,1,0)" IS 1
then without a proper knowledge you will be lost in that code
I am aware of that it may be near to impossible, to write into the code of Mp3tag all the ready-to-use-negatives, or whatever you ma call it. Or that some expressions may even not it's negatives at all. But there could be a very simple workaround. Because Mp3tag could act like this:
a] users puts the expression in the filter
b] users clicks the button
c] Mp3tag creates a temporary file with all the loaded files
d] Mp3tag creates a temporary file with all the loaded files visible at the given moment with the filter working
e] Mp3tag compares both files and displays only the files not present on the second list
And an even more advenced feature would allow the search within the search [create another reverse list from first reverse list]. And also would make it possible to save a search under for example number from 1 to 10, do that the user could quick and easily compare different searches done at his files. [History of searches is not handy like that]
This idea came to me near the end of this topic: Filter reverse
2] It would be much easier to write and read in the filter field all those complicated codes like the aforementioned one
with different colors in it; just like you can see codes in this forum
[I've put the code i CODEBOX, but the colors / formatting didn't show up; just the code as ordinary text in the box itself, as you can see]
#2
This was implemented in earlier versions of Mp3tag, but has been changed, and I do not miss it.
The proper knowledge is laid down in the Mp3tag help manual, and even more special refinements are buried here in the Forum.
For your example ...
"$ifgreater($strstr($lower($left(%TITLE%,6)),$lower($left(%ALBUM%,6))),0,1,0)" IS 1
... the inversion is ...
NOT "$ifgreater($strstr($lower($left(%TITLE%,6)),$lower($left(%ALBUM%,6))),0,1,0)" IS 1
... or ...
"$ifgreater($strstr($lower($left(%TITLE%,6)),$lower($left(%ALBUM%,6))),0,1,0)" IS 0
DD.20150226.0855.CET
#3
As soon as you enter the world of true expressions like
%_filename_ext% HAS "jpg" AND NOT %_filename% HAS Cover AND NOT %_filename% IS folder
it is not clear, what a filter-inverter would do. Invert the first, second or third expression? Or all?
Probably all.
Having such a powerful query language at hand will enable you to pinpoint more or less any set of data.
Actually, the option to search through a set of records would not be necessary if you expand the filter expression with the search term.
This has the discrete charme that you do not have to hop through a lengthy list but you see at one glance (at the bottom in the status bar) how many hits you would have got.
It is a different concept to e.g. searches in word processing but once you get the hang of it you will see the benefits.
#4
Every additional click or keyborad stroke is just... another click or stroke
