ppa
July 20, 2020, 9:30am
1
Can i add a directory then bulk search and remove from tag, for example mine have artist-title (extended)(intro) i want to remove the (extended)(intro) from all mp3s?
ppa:
remove from tag,
I hope we are really talking about the tags - and not the filename.
Yes, you can replace data with an action of the type "Replace".
See e.g. the help
or the FAQs:
How to replace the string "xyz" in tag-fields or filenames?
Create a new action in an existing action group and choose Replace as action type.
Field specifies the parts of the tags/filename the replace rule should be applied to.
Original is the string that is going to be changed in Field.
Replace with is the string that replaces the string in Original. If you leave it empty, the string will be deleted.
ppa
July 20, 2020, 9:55am
3
yes the tags, i will see if i can follow this thanks
