Version 3.31a
I can adjust column widths in the Find window (Ctrl-F) but the adjustments are ignored on the very next Find. Is there a setting somewhere to that will make column width adjustments stay where I set them?
Maybe an option for the future would be to have a toggle between user-defined column widths and the current behaviour of fitting the column widths to the data. However, I believe that user-defined column widths should be the default.
