My BPM tags are like this: "00098 BPM" (without the quotes of course)
I want to remove the leading zeros, and the trailing " BPM", I've tried every option I could find, replace with regex, format value, etc; I've copied and modiefed the regexs here, and I've even tried replacing BPM with nothing, and NOTHING will work, idk what i'm doing wrong at this point.
Make sure that you have set Mp3tag to read the proper tag-type.
Load one media file into Mp3tag, from which you know for sure, that there is such a BPM string in the tag data.
Select the file and open the dialog "Extended Tags...:".
Do you see such value '00098 BPM' in the 'Metadata' list?
What is the name of the tag-field with this value?
