I'm during a batch action to rename sub-folders based on the parent_directory using the following action
%_parent_directory%,7) - Artwork
While runnig the action, I often get an error msg:
The filename would be too long for the destination folder.
I created this action "$cutRight(%_parent_directory%,7) - Artwork" thinking It will resolve the issue but in some cases it doesn't.
Is it possible to create an action that implies:
If Parent_directory & filename are too long... delete as many characters as need to rename folder.
Thanks
