how to force Mp3Tag to add both FLAC and ID3v2 tags to FLAC files ?
I know, you will say me that it's not a good thing but windows explorer and my audio player/converter don't read FLAC tags...
Thanks, Mistic.
Thanks, Mistic.
up plz
Change the file extension to "MP3", write the tags, and then change the file extension back to "FLAC".
And you're correct, most people will say that is a bad idea. It may be better to change audio players (Winamp, for example) or add a plugin (to WMP, for example).
Jim
