I understand. So, this tag labelled "FLAC(FLAC ID3V2)" simply means "FLAC" ?
I tried to erase the item "(FLAC ID3V2)" via "options-tag" but the infos are only in it.
At less, that means that there is no conflict
" To nobody, except those who will take pleasure here "
(Franz Schubert, 31/01/1797 - 19/11/1828)
It means file has FLAC and ID3v2 tags and FLAC tag is displayed.
There are no tag options for flac.
You can try Ctrl+X and then Ctrl+V to remove ID3v2.
PS: If you want to have this quote in every post, add it as signature.
