Flac version 1.4.x and tags
as is turns out, with version 1.4.x of flac if will flag the flac file to be in error if it contains a ID3v2 tag --- is there anyway that mp3tag can find and edit them out?
you could filter for files with
%_tag% HAS ID3 AND %_tag% HAS flac
Then you cut and paste the tags. This will leave only the vorbis comments in the FLAC files.
I am not sure where / how to use
flac files were created with EAC, when I view then with mp3tag, the column “tag” has the value
FLAC (FLAC ID3v2 ID3v1)
When I checked the forums for EAC I was told to “uncheck” the ID3 flag, and when I did that the file now just have
FLAC (FLAC)
in the tag column. The also noted in the comment at eac forum that mp3tag can remove the ID3 tag, but did not say how — any pointers would be appreciated
Thanks
it seems that this is a known issue --- I found that ctrl-x / ctrl-v works --- thanks for the info
WHich is what I tried to describe with
See the documentation:
And on the problem in general:
thanks again --- just one curious question -- does the 64bit version now allow the cut/past to also "past" the cover art back to the files?
have you tried it? That would be the fastest way to find out.
yes I did and found the cover art back in the tracks after the past ---- there was an old post about this issue --- thanks again
