I've many subfolders ( nearly 2000 ) under my Music folder in Windows 11.Under each folder I can create playlist m3u including all the mp3 files having the same name with the folder.Is there an easy way to do it at the whole Music folder with the subfolders.
You could start here:
Please let us know if you need some specific help or if something does not work as expected for you. Let us see your definitions in the Playlist generator, if you have questions.
