Today I go to use MP3Tag (ver 2.39) and a dialog box comes up saying
"This version of MP3Tag was released some time ago ......
Do you want to download the new version?"
If I say NO it STILL asks me next time I use it and the time after that. How long does this go on?
I cannot find anyway to turn this off.
Are you in fact forcing people to upgrade with a nag screen? Very uncool.
If this is not the case I apologise but I hate software which does this. I used another piece of software that had the same sort of nag screen that rendered it useless because it was no longer developed. So as soon as you stop releasing new versions it becomes crippled a few months later.
If your software phones home then there should be an option to turn that off, either way it sucks.
Again I apologise if there is an easy fix for this.
