Using format directory to move files to new location, than trying to create Disc Folders using format filename in the newly created directory location however:
Format Directory - moves folder to new location
Format Filename - generates Disc folders but pulls files back to original location to do so?
Why is that and how can I achieve my end result without having to pull the new directory folder into MP3tag and than run the format filename?
I did try absolute paths as well as some options suggested by Dano/Damage after searching the previous entries in the forums dating all the way back to the beginning...no love there either.
Like this one from 2010:
Format Value
Field: _FILENAME
Format string: %_folderpath%$if($geql(%discnumber%,1),CD $num(%discnumber%,1),)%_filename%
however this one created folders with the complete folderpath which is not what I was after...
Was hoping to get some new insight by asking again...
I think that it is still true that actions to rename files or folders are always executed last in a row of actions.
So, the simplest way would be to start the action for folders apart from the one for filenames.
But you already got that advice.
I am just looking at options and/or a different perspective...Apologies if you seem put out by this as that was not my intent as you are a wealth of insight.
This looks as an improper usage of the function $mid(string,startposition,length).
Within this regular expression ...
$regexp(%album%,'^.* (Volume \D+).*$','$1')
... there is applied the placeholder \D, ... which specifies a non-digit-value, ...
is this intended?
To move a file to a new location and define folders, you may apply such a formatstring ...
Action: Format Value ... on field: _FILENAME ...
Formatstring:
So basically I have bastardized this function however it does exactly what I need it to do and I do not require one function for each item (Hands|Festival|Sampler|Compilation|Volume|Part)..however as it does work I think that I will not be trying to correct my error...
Guess sometimes the easiest way to do something is by accident...
I completely agree: I tried it with
$mid(%album%, (Diary|Festival|Sampler|Compilation|Volume),999)
for an Album called "Ambient.Diary One"
and it returns nothing.
It would seem that I owe you both an apology. I went back and took another look at the action itself and ran it singularly ....and you both are 100% correct, this actually does nothing at all....
When I entered this I added it to a UTILS action grouping that had an action that already populated the guess value fields...so I mistook this as the action that did it...my sincerest apologies
