Hi there
I current have an action on the _DIRECTORY to rename the folder using the following action after I tag the FLACs using Discogs:
Format Value "_DIRECTORY": %artist% - %album% '('%mediatype%')' '['%publisher%, %CATALOGID%']'
When I rename the folder, it gives me this:
Genius GZA - Shadowboxin' 4th Chamber (CD (Maxi-Single, Promo)) [Geffen Records, PRO-CD-4853]
I want to replace this:
with:
(CD, Maxi-Single, Promo)
Thanks in advance for any help!!
Provided there are never any brackets in the album part ..
I would use an action group with 2 actions of the type simple "Replace"
first,
Search: _(
Replace: ,_
(where the underscore represents a space character)
second:
Search: ))
Replace: )
Hi thanks for your help. The second part of the example you gave me worked like a charm
Here is an example of what I am working with:
Little Indian - One Little Indian (CD (Single, Promo) [Premeditated, PRO-CD-7804]
What I want to do is replace all instances of (anydata (anydata,anydata) so it looks like
(anydata, anydata, anydata)
I basically just want to remove the 2nd ( in that particular section of the string and replace it with a comma.
I am guessing I can use this to search
Search:
but what do I replace with?
Try:
Search string:(.*) \((.*)
Replace string: $1, $2
