Format string to replace characters with accents
Hi there,
I am working on a format string to replace accents/special characters (mostly from Vietnamese) with normal characters so I can search for them on Piooner devices.
Here is the full format string:
$validate($replace( %title%,ä,a,á,a,à,a,ả,a,ã,a,ạ,a,â,a,ấ,a,ầ,a,ẩ,a,ẫ,a,ậ,a,ă,a,ắ,a,ằ,a,ẳ,a,ẵ,a,ặ,a,ë,e,é,e,è,e,ẻ,e,ẽ,e,ẹ,e,ê,e,ế,e,ề,e,ể,e,ễ,e,ệ,e,í,i,ì,i,ỉ,i,ĩ,i,ị,i,ö,o,ó,o,ò,o,ỏ,o,õ,o,ọ,o,ô,o,ố,o,ồ,o,ổ,o,ỗ,o,ộ,o,ơ,o,ớ,o,ờ,o,ở,o,ỡ,o,ợ,o,ü,u,ú,u,ù,u,ủ,u,ũ,u,ụ,u,ư,u,ứ,u,ừ,u,ử,u,ữ,u,ự,u,đ,d,ñ,n,Ä,A,Á,A,À,A,Ả,A,Ã,A,Ạ,A,Â,A,Ấ,A,Ầ,A,Ẩ,A,Ẫ,A,Ậ,A,Ă,A,Ắ,A,Ằ,A,Ẳ,A,Ẵ,A,Ặ,A,Ë,E,É,E,È,E,Ẻ,E,Ẽ,E,Ẹ,E,Ê,E,Ế,E,Ề,E,Ể,E,Ễ,E,Ệ,E,Í,I,Ì,I,Ỉ,I,Ĩ,I,Ị,I,Ö,O,Ó,O,Ò,O,Ỏ,O,Õ,O,Ọ,O,Ô,O,Ố,O,Ồ,O,Ổ,O,Ỗ,O,Ộ,O,Ơ,O,Ớ,O,Ờ,O,Ở,O,Ỡ,O,Ợ,O,Ü,U,Ú,U,Ù,U,Ủ,U,Ũ,U,Ụ,U,Ư,U,Ứ,U,Ừ,U,Ử,U,Ữ,U,Ự,U,Đ,D,Ñ,N,ç,c,ß,ss,œ,oe,Œ,OE,),)
Here are all the special characters so you can test them:
ä,á,à,ả,ã,ạ,â,ấ,ầ,ẩ,ẫ,ậ,ă,ắ,ằ,ẳ,ẵ,ặ,ë,é,è,ẻ,ẽ,ẹ,ê,ế,ề,ể,ễ,ệ,í,ì,ỉ,ĩ,ị,ö,ó,ò,ỏ,õ,ọ,ô,ố,ồ,ổ,ỗ,ộ,ơ,ớ,ờ,ở,ỡ,ợ,ü,ú,ù,ủ,ũ,ụ,ư,ứ,ừ,ử,ữ,ự,đ,ñ,Ä,Á,À,Ả,Ã,Ạ,Â,Ấ,Ầ,Ẩ,Ẫ,Ậ,Ă,Ắ,Ằ,Ẳ,Ẵ,Ặ,Ë,É,È,Ẻ,Ẽ,Ẹ,Ê,Ế,Ề,Ể,Ễ,Ệ,Í,Ì,Ỉ,Ĩ,Ị,Ö,Ó,Ò,Ỏ,Õ,Ọ,Ô,Ố,Ồ,Ổ,Ỗ,Ộ,Ơ,Ớ,Ờ,Ở,Ỡ,Ợ,Ü,Ú,Ù,Ủ,Ũ,Ụ,Ư,Ứ,Ừ,Ử,Ữ,Ự,Đ,Ñ,ç,ß,œ,Œ.
It works until the last "e"; everything after it will not be replaced.
Could someone help me out? I am not a coder so I don't know if I did something wrong with it or maybe I have exceeded the maximum number of characters that could be replaced.
Thank you!
You have to split $replace() into several statements. The one that you present is too long as it exceeds the maximum 64 parameters.
grafik
Could you please tell me how to split them into several statements?
You have to create an action group with several actions that feature the $replace function.
You have probably already created an action group to house the initial $replace.
Now edit that group and copy the existing action a couple of times.
Then edit each of the copies and delete all the pairs that have been dealt with in another (copy of the) action.
A good measure is to use no more than 30 replace-pairs per action call.
Finally, save the action group with OK.
Thank you!
I am at this point. Do I have to enter each pair or is there a way to enter 30 pairs at once like you said?
If you want to use $REPLACE() then you have to use an action that allows a format string, e.g. "Format value".
Also, I would not use _TAG as target for the replacement but dedicated fields.
The function to copy actions should make that an easy option.
