Hopefully a simple question:
How do you delete a format string template from the list under sub-menus of Convert? The obvious delete key doesn't work for this.
Thx!! Ray
Thx!! Ray
Open the dialogue,
select the item you want to delete
Press the arrow-button next to the input box and select "Delete from list".
