Ok here's my problem with MP3tag newer versions and why I remain using the older versions.
I remove a tag. I have the program setup to pick up the artist name and title from the file name. I click on convert from file name to tag. And immediately I get a dialouge box wanting me to choose the artist-title format for each file. There should be a default setting where I don't have to do this. just hit the convert and method and wham - every file in my list gets converted in the selected manner- in my case from filename to artist-tag. I shouldn;t have to select this option for every file.
Previous versions did not have this "problem" All the files wer converted in the same manner
secondly
In the comments section I want to add my "Handle" So I set up a COMMENTS Action I formatted the value. But when I select the files and hit actions to fill in the comments field I have to select the Comments field for every file and choose the format value Again, previous versions did not require I do this.
Makes no sense that one would have to do this.
Please return this to the way it was in 2.39 or allow a default value to be set so that everytime we do a conversion we don;t have to go through this. thanks
