First of all I'd like to say that this program is amazing and the people who post in this forum are equally amazing, I've found a great script for moving all my "feat. abc" from artist to title.
My problem is that I have tons of remixes and the "feat. abc" gets moved to the end, after (xyz Remix). Could someone please help me to make the following changes?
From: Title: Move (Club Mix)(feat. Max'C) Title: I'm Alright (Chuckie Remix)(feat. Flo Rida & Kat Deluna)
Result: Title: Move (feat. Max'C)(Club Mix) Title: I'm Alright (feat. Flo Rida & Kat Deluna)(Chuckie Remix)
Thank you so much for your time and help in advance!
Charlie
Hi Charlie, good to hear, that the "feat" challenge is alreay done by you, so your current request might be an easy one, at least one similar request including solution should be buried down in the forum posts.
To make it short ... use ...
Action: "Format value"
Field: TITLE
Formatstring: $regexp(%TITLE%,'^(.+?)\s((.+?))\s((feat.\s.+?))$','$1 $3 $2')
A (B) (feat. C)
To:
A (feat. C) (B)
If this swapping of parts should be applied against the filename, then it is rather simple too.
