Format Value with regexp from another field
Suppose I have track names (TITLE) like this on one CD:
Tambourin (Rameau)
Courante (Lully)
What I'd like to do is extract the composer names (Rameau and Lully) and put them into the COMPOSER field, which is a custom field I've set up in my own tagging system geared toward classical music.
Of course, I can easily remove the composer from the TITLE field like this:
(.) ((.))$ ---> $1
But when creating a new action of "Format Value," I don't see any way to extract specific parts of the TITLE field and put it into the COMPOSER field.
COMPOSER is no custom field but a standard one.
An action of the type "Guess value" for
source: %title%
Pattern: %title% (%composer%)
might help you.
Or to edit your reg expression..
Format action.
Format: COMPOSER
With: $regexp(%composer%,.*(([^(]+))$,$1)
