Anyone know how to get this ID3 Frame inspector Axone.jar to run via the cmd.exe or if you know of any other I could check out?
e.g. "C:\Users\stevehero\Desktop\Axone.jar" "'%_path%'"
HOMEPAGE: http://flying.guy.chez-alice.fr/Axone.php
DOWNLOAD: http://flying.guy.chez-alice.fr/Axone.jar
Basically, it's just a little powerful utility to inspect each frame of ID3 versions. Can even read corrupt frames when you might see that ID3v2: !BAD message in Mp3tag.
You might think your tags are lost, they're there but just not readable apart from that one BAD frame.
Thanks.
It is a bit unusual to use. In my opinion, the free Medieval CUE splitter application is also suitable for this purpose: Tools >> Audio file information. I use it mostly to identify, is a field any standard, or TXXX. Good for FLAC and MP3, i have not tried anything else.
Download a portable Version of Java**, like jPortable (portable Java® runtime environment (JRE)) | PortableApps.com
"Install" (=extract) it.
Create a new batch file (like run_Axone.cmd) in the same folder as you have downloaded the Axone.jar, including the line
Path_to_your_extracted_portable_JAVA\CommonFiles\Java\bin\java.exe -jar Axone.jar
Press the little "open folder" icon in the upper left corner of the Axone-Java-Window.
** I don't like how Java integrate itself into windows, therefore I prefer a portable version.
I didn't even have it installed on my system.
I got the 64 bit offline versin of java and created a batch file like so:
@echo off
for /f "tokens=* usebackq" %%F in (`where java`) do (set javaInstallPath=%%F)
"%javaInstallPath%" -jar "C:\Users\stevehero\Desktop\Axone.jar"
If only there was a parameter to open the file like below:
"%javaInstallPath%" -jar "C:\Users\stevehero\Desktop\Axone.jar" "filename"
Thanks for this. I haven't needed it since this post but you never know.
