freedb local
I have stared to organize my training audios. I would like to setup a local db to list name, year, comments and topic. My Tag Sources list freedb but it is grayed out.
Where can I get nearly blank one and expand it as I add audio files.
thanks.
You have to set a path in File>Options>Freedb to access a local copy of the official net freedb.
The freedb is for reference and especially well suited to deal with CDs and their ID.
User DetlevD regularly supplies an updated version of the freedb: /t/18288/1
And perhaps there is a basic misunderstanding: the tag sources are actually the sources and not the targets for tagging. So you would not write anything to the database.
Perhaps you have a look at the export function and options you have there to generate a formatted output in the way you like.
