Hi. I've been using mp3tag for a couple of years now, and though I don't use it often, I have found the method of album looking of "Tag Sources" and "freedb" to be almost always perfect. However, just in the past month or two I've been striking out completely with that method. I suppose it's possible that the albums I'm looking up just aren't in the database (or are there under a different name), but maybe I'm doing something wrong or maybe there's a problem with mp3tag. Questions:
- Has anything changed in mp3tag, or in the way mp3tag connects to freedb, that might be causing my problems, and if so, do you have a fix?
- Has anyone else been having this problem? (If not, I'm going to assume it's "user error", namely my problem.
Thoughts?
Thanks,
DB
