is it possible to do a web source script without user interaction?
I've taken an existing lyrics web source script and modified it so it works fine. Is there a way I can do it so it works with multiple files and doesn't prompt for either the search or the tag writing?
Also, is there a way I can abort if the lyrics tag is already populated or if the script fails to find the lyrics?
thanks in advance
