Generic Audio Player
Hello Florian, and thanks for a continued great work and detailed information on your advanced Tagging Program for so many years.. It's Appreciated!
I just have a non-critical request to see if it may be possible to implement an internal generic audio player to the program so the user do not have to use their local audio player?
Basically, just a simple audio player that can instantly play the song for quick listening when the user have, possibly, many files they may want to compare or analyze the file at hand within a list.
As I somewhat stated, it is not very important, however, It will be convenient and could save time for quick playback for analyzing and/or comparing.
Thanks for considering. Sincerely, Artie (snp)
see e.g. here:
or here:
or here:
esp. the hint to use foobar2000 may be useful. You can drag&drop files between MP3tag and Foobar2000 either for tagging or for listening - and see them side by side at the same time
