Is there a good Web Sources Script for importing genre information? The last.fm one used to work well, but it seems to have broke.
Thanks in advance...
This section of the forum
/c/web-sources-scripts
has some more web sources scripts. Perhaps you find one that you consider as good.
Thanks -- I know where the scripts are. I was hoping for a more curated answer.
I'll go poke around some more.
