How do I do this, please?
You can add this new custom field to an arbitrary file via the extended tag dialog. After restarting Mp3tag it should also be listed as possible filter field.
And yes, there need to be a better way of doing this. It's on my list...
Thanks. May I suggest this secret feature be mentioned in Help?
Field: as combo box would suit me fine. Ideally responding to Delete.
I'm trying to do similar in 2.41
I've loaded 7k worth of apple lossless files, I want to filter field "Encoder" by a value of "."
But I can't, even though this field is present in (most) of the files.
What am I doing wrong, please?
Sorry, I've learnt how to read now, and sorted it.
Sorry for wasting your electrons
