Hi folks,
I have recently decided to change my disc-numbering system to use %totaldiscs%.
Right now i use #/# ie 3/4 or 11/14 in %discnumber%
i want to copy '#' ie /# or /## without the slash into %totaldiscs% and then remove the / and numbers after it from %discumber%
i can't use $cut due to the mix of singular and double numbers
Is there away to select numbers before and after a symbol in tag-tag or some other tool?
