Hi i wonder if there is a possibility to group files per folder and if there is a way to select all the files in the folder by clicking the group's header. I tried to find a setting about it but i can't find any.
This is a screenshot from another program were you can do what i'm describing above.
I donʼt need this for folders, but it would be nice to have for files with chapters – if it was implemented for that, it would probably be rather simple to add for folders or even for arbitrary columns as well.
