As I moved to Mac, trying to switch over to Mp3Tag MacOS native version.
To achieve that, I started manually migrating all my Actions over from Windows version (there is no possibility to import these) and stumbled onto an serious blocker.
Looks like MacOS versions lacks "Guess values" action, which pretty much means I cannot switch.
Are there any plans to add this, or I am completely out of luck
And it works fine in Windows version, using "Guess values"
Now tried your suggestion @ohrenkino and used it with "import tag fields" action and it does not seem to work at all.
Perhaps you use a small test case to see whether the basic functionality is there and then you debug the more complex expression that you used in windows and transferred to the Mac.
Ok, disregard my comment...last one did work, after I renamed Folder to "test1 - test2" (apparently I had excess space in the fodler name, which I did not notice)
Now wondering, why Regex is not...
IMHO, not entirely.
As apparently, functionality is not quite 1:1 (regex handling).
But you are right, its is now more about general Regex handling in MacOS, rather than missing action.
Fair enough, will spawn an separate thread.
