Well, the regex works spot on but it's unflexible.
Is it possible to turn it into a conditional such as this abstract demonstration:
If %artist% has name/name/name, change to "name feat. name & name". If %artist% has "name/name" then "name feat. name". If %artist% has "name" leave untouched.
Well, this may be but on the other hand: language is so flexible. I can think of at least two artists that would fall into your pattern but shouldn't: AC/DC and Colourbox M/A/R/R/S
So, unless you have an absolutely unique separator between your artists (who, by the way, tagged them like that in the first place? Usually WMP transforms such a slash into a semicolon ...) it would be a good idea to filter the tracks first and check what kind of irregular entries you have.
You did not ask for flexibility the first time.
Anyway, here you go:
$ifgreater($strrchr(%artist%,/),$strchr(%artist%,/),$regexp(%artist%,(.)/(.)/(.),$1 feat. $2 & $3),$regexp(%artist%,(.)/(.*),$1 feat. $2))
Does not work for artist names with "/" in it like AC/DC and M/A/R/R/S and for collaborations of more than three artists.
